We have one business requirement where user will import batch number dimension with customized excel import functionality before posting Packing Slip.
My question is how i can update the dimension on Packing Slip form(or purchparmline) because everything is coming from Purchase Line table and dimension id will be same across purchase line, inventtrans ? Kindly help.
Created a query with PurchTable > PurchLine > InventDim relation. Created document service using wizard, then for import button created a class and methods as per required. Then at the time of import from excel, first i am checking whether the InventBatch table is having similar batch id or not, if not then first i am inserting a record for new inventbatchid in the respective table. Then to update purchline inventory dimensions i wrote a join query between purchline and inventdim and updating inventdimid by using findorcreate method of inventdim table by passing new dimensions. Then to update purchparmline table i have used relation of PurchParmLine.PurchLineRecID = PurchLine.RecId. So now it is working fine.
I am having same scenario like you. I am using SalesPackingslip Service to create Packing slip of particular sales order from C#. I wanted to pass InventBatchId from that service. but It is not allowed, since it is updated from SalesLine Table. so how can I pass inventBatchId from C#.
