How can i use a string variable in Select statement in the fallowin code ?
static void Job3(Args _args)
dialog dlg;
DialogGroup dlgGroup;
DialogField dlgField;
str S;
// int A;
CustTable custTable;
dlg = new dialog();
dlgGroup=dlg.addGroup(“Customer”);
dlgField=dlg.addField(Typeid(CustAccount),“Account Number”);
if(dlg.run())
S=dlgField.value();
// A =str2int(s);
select custTable where custTable.AccountNum ==S;
print "This is the address of Customer " + custTable.AccountNum + ": " + custTable.Address;
pause;
