I am using a XML Port to import records. If any one of the field is blank, is it possible to skip the record ( This is a new record not an existing record).
Is there is a way to skip a particular record if the validation fails and insert other records.
Did you get the solution for your problem? If you have then it would be very helpful if you post it in Navision or drop the solution to ersangamshrestha@live.com.
