I have created lookup using the following code and the output for the code is also given below. here I able to select only one record at a time in the lookup field. but I want to select multiple values in the single lookup field based on I want to get the values.
class CustCreateDialog1 extends RunBaseBatch
DialogField fieldAccount,fieldAccount1,fieldAccount2,fieldAccount3;
DialogFIeld fieldName;
CustTable custTable;
CustAccount custAccount;
DirPartyName dirPartyName;
ItemId itemId;
SysLookupMultiSelectCtrl msCtrl;
QueryRun queryRun;
FormStringControl fsc;
FormBuildControl fbc;
FormBuildStringControl fbsc;
protected Object Dialog()
//FormRun fr;
Dialog dialog;
//fr = dialog.dialogForm().formRun();
dialog = super();
// Set a title for dialog
dialog.caption( 'Simple Dialog');
// Add a new field to Dialog
fieldAccount = dialog.addField( extendedTypeStr(CustAccount), 'Customer account' );
fieldAccount1=dialog.addField( extendedTypeStr(ItemId), 'Item Id' );
fieldAccount2=dialog.addField( extendedTypeStr(DirPartyName), 'Vendor Name' );
// msCtrl = SysLookupMultiSelectCtrl::construct(element, TestCtrl, querystr(StudentCourse));
// sysms = SysLookupMultiSelectCtrl::construct(fr, Fr.design().control(fieldAccount, queryStr(VT_UserInfoQuery));
return dialog;
public boolean getFromDialog()
// Retrieve values from Dialog
custAccount = fieldAccount.value();
ItemId=fieldaccount1.value();
dirPartyName =fieldaccount2.value();
return super();
public static void main(Args _args)
CustCreateDialog1 custCreate = new CustCreateDialog1();
// Prompt the dialog, if user clicks in OK it returns true
if (custCreate.prompt())
custCreate.run();
public void run()
SysExcelApplication xlsApplication;
SysExcelWorkBooks xlsWorkBookCollection;
SysExcelWorkBook xlsWorkBook;
SysExcelWorkSheets xlsWorkSheetCollection;
SysExcelWorkSheet xlsWorkSheet;
SysExcelRange xlsRange;
//CustTable custTable;
int row = 1;
str fileName;
DirPartyTable dirPartyTable;
InventTable inventTable;
// Set Dialog field value to find CustTable
//custTable = CustTable::find(custAccount);
if (custAccount)
// Shows retrieved information
//Filename
fileName = "C:\\Test.xlsx";
//Initialize Excel instance
xlsApplication = SysExcelApplication::construct();
//Open Excel document
//xlsApplication.visible(true);
//Create Excel WorkBook and WorkSheet
xlsWorkBookCollection = xlsApplication.workbooks();
xlsWorkBook = xlsWorkBookCollection.add();
xlsWorkSheetCollection = xlsWorkBook.worksheets();
xlsWorkSheet = xlsWorkSheetCollection.itemFromNum(1);
//Excel columns captions
xlsWorkSheet.cells().item(row,1).value("Account Num");
xlsWorkSheet.cells().item(row,2).value("Name");
xlsWorkSheet.cells().item(row,3).value("itemId");
// xlsWorkSheet.cells().item(row,4).value("Name");
row++;
//Fill Excel with CustTable AccountNum and Name fields (only 20 records)
while select custTable where custTable.AccountNum==custAccount
select inventTable where inventTable.ItemId==ItemId;
if(row == 20)
break;
xlsWorkSheet.cells().item(row,1).value(custTable.AccountNum);
xlsWorkSheet.cells().item(row,2).value(custTable.Name());
xlsWorkSheet.cells().item(row,3).value(inventTable.ItemId);
row++;
//Check whether the document already exists
if(WinApi::fileExists(fileName))
WinApi::deleteFile(fileName);
//Save Excel document
xlsWorkbook.saveAs(fileName);
//Close Excel
//xlsApplication.quit();
//xlsApplication.finalize();
else
error( 'Customer Account not found!');
output:
