Multi select Lookup in dialog class using Enum Field in ax 2012
I have 2 multiselect dialog field in which both are enums, when I select multiple values from the lookup the values displayed in the dialogfield control is 0;1 … etc instead of this I want to display the enum label in the test box how to achieve this in dialog class in ax 2012. Please suggest an answer.
Thanks in advance,
Gopinath M.
I have achieved multiselect lookup using “SysLookupMultiSelectCtrl” , I request you to suggest a solution to display the select enum label instead of enum value (like 0,1,2). Please suggest an solution.
Gopinath M.
TO solve this issue I used two temporary tables in which i populated the enum’s id and value and used in the query which will populate the two multiselect drop downs . And it is working fine.
