How to insert records already exist in the form into a new line of the same form.
and the new line should generate a next number sequence id(which was fetching using
number sequence format).
please send some coding
numberSeq::newGetNum(NumberSequenceReference);
before use this function you must have a method in table to create a new numbersequence
Example:
i had one table “RMResourceReqLine” in that table i had the below method (it used to return created new numbersequence)
static client server NumberSequenceReference numRefId()
return NumberSeqReference::findReference(typeId2ExtendedTypeId(typeId(RMLineID)));
RMLineId - EDT for that numberSequence.
now call this method like this
numberSeq::newGetNum(RMResourceReqLine::numRefId).num();
now this method return the newly created numbersequence…
inserting thing…i hope you know…
numberSequenceReference = smmParametersTable::numRefCaseId();
if (numberSequenceReference)
numberSeq = NumberSeq::newGetNum(numberSequenceReference, false,true);
if (numberSeq)
caseidlocal = numberSeq.num();
issueTrackerLocal1.CaseID = caseidlocal;
smmparameter-module name
caseidlocal - field variable
issueTrackerLocal1 - new line table variable
Hi everybody,
thank u very much for urs help…
smiley
