in ax 2012 ,I have a report and I am trying to give diffrent ranges for different companies,usually I was using table’s range to give range to report but they want;
A is company and They should see 1 on the mainaccount’s fieldon dialog page
B is company and They should see 2 on the mainaccount’s field on dialog page
hello kranthi,
I want to use diffenet values range for same report in different companies,no actually it is not mainaccounttable i just wrote for example…
they want the filter the report by different ranges on different companies,ı have range on my repor’s database and its 1,and locked value but they want 2 for company A and 1 for company B but also they are in the same company they use comman aot,workspace,so if i change the Company’s a value b is changing also.So I should do crosscompany for the report but I do not know how to use it.i have a A and B company ,they are using some report but they should have different range .
