Regarding AX report Index Field in Range
When I create a report that is started from a class, using for instance the tables SalesTable and SalesLine, and I have no range on the salesline, when I prompt the Query, the Index fields SalesId and Linenum are shown. when I reset the query, the normal selection shows up, but it is no syslastvalue issue. When I put a range in the salesline, these fields do not show up in the query prompt. Has anyone have an idea to solve this, when I do not want a range on the salesline.
Thanks in Advance
Janak Talekar
