Dynamics AX 2012 comes with unit testing support.
To have meaningful tests some test data needs to be provided (stored in tables in the database). To get a reproducable outcome of the unit tests we need to have the same data stored in the tables every time the tests are run. Now the question is, how can we accomplish this?
I learned that there is the possibility of setting the isolation level for the TestSuite to SysTestSuiteCompanyIsolateClass. This will create an empty company and delete the company after the tests have been run. In the setup() method I can fill my testdata into the tables with insert statements. This works fine for small scenarios but becomes cumbersome very fast if you have a real life project.
I was wondering if there is anyone out there with a practical solution of how to use the X++ Unit Test Framework in a real world scenario. Any input is very much appreciated.
