Dear ax professionals,
I have one doubt.can any body tell me…
how to create the balance sheet.
how to setup balance sheet in ax 2009
please clarify the step by step…
after creating the balance sheet how it will be open
Thanks and regards
Thanks and regards
You need to make use of the Financial statement ( GL → setup → Financial statement)
hi kranthi …
Thanks for giving the reply…if you don’t mind
can you tell me the briefly please
step by step
Thanks and regards
Hi Venkatesh,
Balance sheet can be created in AX using financial statement.
FS consists of mainly two sections, Collumn defination and row defination.
Collumn defination will create different collumns, say 2011 and 2012 for showing balance deteils for respective years.
Row defination, being more important, is used to combine different ledgersaccording to requirement.
To run the report, go to Gl, Reports, Transaction, Financial statement.
Select the appropiate row and collum defination and run the report.
Pranav…
