I need to be able to create a basic balance sheet by using the financial statement functionality with ax 2009. can someone pls give me directions
If you are looking for step by step instruction, you can refer the user manual from MS in AX 2009, FIN II Chapter 11, which covers all the basics.
How would I obtain it?
Talk to your AX vendor or support, they should have it when you bought AX. I am not sure if I am supposed to share the file.
How do I increase the column width of the names of the accounts in the balance sheet?
