how to connect navision to vb
hi everyone… i would like to know ho to connect navision with vb thanks
Hi I think you asked this question across various forums yesterday, and today you ask it three times in the same one - is this a new approach? [:D]
there were problemes with internet and put 3 times ta same message… i’ve done the connection with vb to navision and i want to do the opposite
You could delete the other two messages as you are the author!
I would create an OCX in VB and then register the control in Navision. Then when you come to define your variables (in Navision)… Select type of OCX and select your OCX. Then you can call your functions using the standard Symbol Menu to enter your code… Technically not connecting to VB but whatever you have the VB code connecting too… [;)] Cheers A [}:)]
and how can i do that? i a little new in this thanks in advance for your help
Hi… Yes i have given an example before… Please go to the link below… http://www.navision.net/forum/topic.asp?TOPIC_ID=4113 The part you are looking for is about 8 posts down under my name… Good luck! [;)]
