hai all
I want to ask you something, How to compare record with the previous record on a form?
for example like this :
document no new
DOC001 yes
DOC001 no
DOC001 no
DOC002 yes
DOC002 no
so every new document, the new field should be yes
thanks
hai all
document no new
DOC001 yes
DOC001 no
DOC001 no
DOC002 yes
DOC002 no
thanks
Try this code in OnAfterGetRecord and OnAfterGetCurrRecord:
Record.copy(Rec);
if not Record.next(-1) then
New := true
else
New := Record.“Document No.” <> “Document No.”
My code
Form - OnAfterGetRecord()
TransferOrder.copy(Rec);
if NOT TRansferOrder.next(-1) then
Status := true
else
Status := TransferOrder.“Location Code” <> “Location Code”
error message : This prefix operator cannot be used on integer
Sorry:
if TRansferOrder.next(-1) = 0 then
Status := true
else
Nice Valentin !!
it works …
thanks a lot
I’m sorry… I forget to add this
how about if I want to add increasing number from no series
document no new no
DOC001 yes 1
DOC001 no 1
DOC001 no 1
DOC002 yes 2
DOC002 no 2
I get number series from here
NoSeriesLine.SETRANGE(NoSeriesLine.“Series Code”,‘T-ORD’,‘T-ORD’);
(INCSTR(NoSeriesLine.“Last No. Used”)
This can reduce performance… Are you sure you want do this?
yes … no problem
