I want to add ItemGroupId,ProductName fields in ItemId Lookup.
In Standard code is there in LookupItem metho in InventTable
But It is Showing only ItemId,SearchName,ItemType,Product But It is not showing ItemGroupId,DefaultProductName.
The standard code in LookupItem:
/// Provides a lookup for the InventTable table.
/// The form string control object with which to perform the lookup.
public client static void lookupItem(FormStringControl _ctrl)
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(InventTable),_ctrl);
Query query = new Query();
QueryBuildDataSource queryBuildDataSource = query.addDataSource(tableNum(InventTable));
sysTableLookup.addLookupfield(fieldNum(InventTable,ItemId));
sysTableLookup.addLookupMethod(tableMethodStr(InventTable,itemGroupId));
sysTableLookup.addLookupMethod(tableMethodStr(InventTable,defaultProductName));
sysTableLookup.addLookupfield(fieldNum(InventTable,NameAlias));
sysTableLookup.addLookupfield(fieldNum(InventTable,ItemType));
sysTableLookup.addSelectionField(fieldNum(InventTable,Product));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
Add LookUpMethod values or not showing in ItemId Lookup
Pls Help me How add these 2 fields in Lookup.
Balu
