How to add a method in a lookup in form's field
Can anyone give an idea oh how to add a method to the lookup() in a forms field .
i.e usually we use lookup.addlookupfield(fieldnum(tablename, fieldname));
Now my requirement is i need to bring a method from the table to the lookup…so how should i write code???
i.e lookup.(???)
Use lookUp.addLookupMethod(‘method1’); //here method1 is a display method on the table u lookup
Hi Lilly,
Here is one sample Look Up Method Code
void lookupItemId(FormControl control)
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
SysTableLookup sysTableLookup;
//Create an instance of SysTableLookup with the form control passed in
sysTableLookup = SysTableLookup::newParameters(tablenum(Purchline), control);
//Add the fields to be shown in the lookup form
sysTableLookup.addLookupfield(fieldnum(Purchline,Itemid), true);
sysTableLookup.addLookupMethod(“itemName”);
//Code Added 29 - 03
//sysTableLookup.addLookupfield(fieldnum(Purchline, Linenum), false);
sysTableLookup.addLookupMethod(“IFRBRAND”); --------------------------------------> This is how i use method in a look up from the Datasource PurchLine
sysTableLookup.addLookupfield(fieldnum(Purchline, QtyOrdered), false);
//create the query datasource
queryBuildDataSource = query.addDataSource(tablenum(Purchline));
queryBuildRange = queryBuildDataSource.addRange(fieldnum(Purchline, Purchid));
queryBuildRange.value(IFRShippingPurchTable.PurchId);
//add the query to the lookup form
sysTableLookup.parmQuery(query);
// Perform lookup
sysTableLookup.performFormLookup();
Hi Lilly,
try below code hope it’ll helpfull 4 u
lookup.addLookupMethod(tablemethodstr(tablename,methodname)
hi Mayank k,
Thanks for your reply… Indeed i solved the issue by myself.
is there any way to add a empid(by field), name(by method) in a form’s init() method???
i tried using [tablenum(tablename, field1), tablemethodstr(tablename, methodname)], but i am getting an error… how to solve this? i need to get the display method name next to the emplid???
What you need in your init method? look up field ? On what basis?
Thanks and Regards,
Kevin
Hi Kevin,
I am using this in SysListPanelRelationTableCallback::newForm() …
