I want to import Site specific order setting for item(product) using Excel file. I need to write code.
any one having any idea about this, please share. It will really help full for me.
Thanks in Advance
Thanks in Advance
Hi ,
below code may help u
InventItemPurchSetup inventItemPurchSetup;
InventItemInventSetup inventItemInventSetup;
InventItemSalesSetup inventItemSalesSetup;
inventItemPurchSetup.initValue();
inventItemPurchSetup.ItemId = itemnumber;
inventItemPurchSetup.InventDimId = “dimension id”;
inventItemPurchSetup.InventDimIdDefault =“default dimension id”;
inventItemPurchSetup.insert();
inventItemSalesSetup.initValue();
inventItemSalesSetup.ItemId = itemnumber;
inventItemSalesSetup.InventDimId = “dimension id”;
inventItemSalesSetup.InventDimIdDefault =“default dimension id”;
inventItemSalesSetup.insert();
inventItemInventSetup.initValue();
inventItemInventSetup.ItemId = itemnumber;
inventItemInventSetup.InventDimId = “dimension id”;
inventItemInventSetup.InventDimIdDefault = “default dimension id”;
inventItemInventSetup.insert();
Hi Jagannath T,
I guess I know you, if you are from Drivedge.
Thanks for your help.
It solved my requirement up to on extend.
Thanks again
Hi Nandini,
Yes i am from drivedge :).
Hi Jagannath T,
May I have your gmail ID plz.
