In my query I have:
"where purchTable.PurchStatus < salesTable.SalesStatus"
I get an error because “operand types are not compatible”, but I want to compare the integer values. Is there a way to type cast these in a query or something?
In my query I have:
This Type of direct comparison is not possible.
You can do like this,
create a enum field in your form,
PurchStatus purchstatus;
purchStatus = global::enum2int(salesTable.SalesStatus);
// In your query you compare like this
“Where purchTable.PurchStatus < purchStatus”
If you wannt to compare integervalue use the coding,
EX
global::enum2int(ABC::C) // it will return3
It will return integer value
Regards
P.RAM
My query is a “while select” so I can’t just get the value once unless I planned on doing two nested queries. What I ultimately did was:
where purchTable.purchStatus == 1 &&
(salesTable.salesStatus == 1 ||
salesTable.salesStatus == 2 ||
salesTable.salesStatus == 3)
I think I will write a Macro where I can pass it %1, %2 and that will keep it nice looking. Thanks for the help! I was pretty sure I couldn’t do it the way I wanted to, but I’m glad it was verified.
