Hello!
I want to have the Help of the Ms Nav 5.0 in any pdf or word, where can i find. Exist any way to extract all the help that is in the program.
Thank you!
Hello!
Thank you!
Help files are located in the install directory under Client\ENU (or whatever language code you have). Google “chm to word” or “chm to pdf” to find a converter. I’m sure there are some. CHM is the help file extension.
Actually there is a neat trick posted somewhere on the forum search and you should find it, But basically if you press F1 and open the help, the help system generates a big file in a temp directory somewhere. This is formatted (I think as a RTF file) and you can copy it when the help is open and you have it all in one file.
