Sorry if this seems stup.d, but I’m a newbie to AX devopment, I’m using AX2012, SSRS and VS2010.
I want to create dynamically some labels, all data comes from a table in AX named, PanelProdLabel
ItemId UserId PanelName Product Barcode
00123 lars New Front 7777 99999
00124 jim Back Door 5464 66666
00125 luc Right Mirror 8989 55555
The fields on the label should be arragend like this:
PanelName
Panel: Product
Salesperson: UserId
Barcode
Now I can query the database and print 1 label in a SSRS report at a time, because after print is done the table record is deleted.
I need to print multiple labels in on single sheet of paper according to the records in the above table, not just one at a time.
Can you please show me with some code in AX ? or what would be the best way to acomplish this?
Thanks for your urgent help
