Using AX labels in AX 2009 SSRS report
I’ve just started creating SSRS reports in AX2009. Does anyone know how I can use AX labels in the SSRS report itself? Thanks!
Hello ,
where u want to use lables in report ,if i assume that u r going to use lables in text box then go to the text box property and then expresion window u can find lable node ,here u can select lables as u required.
I was referring to AX labels, for example @SYS12345. Is this applicable in the label node as well? I tried this previously and it didn’t work.
