I need to know in which table GST values are getting stored.
GST rate will come against HSN/SAC code.
Tax setup form - TaxRunTimeSetting using datasource like TaxRuntimeLookupCondition table…
From which table its getting populated.
Any help appreciated.
Thanks.
Got soln.
Tables:
- TaxRuntimeLookupCondition.DimValue2 (HSN code)
TaxRuntimeLookupCondition.DimValue3 (SAC code)
2.TaxRuntimeLookupMeasureResult
3.TaxRuntimeLookupMeasureResultDetail.Value (GST Rate)
Relation:
TaxRuntimeLookupMeasureResult.LookupCondition = TaxRuntimeLookupCondition.RecId
TaxRuntimeLookupMeasureResultDetail.LookupMeasureResult = TaxRuntimeLookupMeasureResult.RecId
Flash,
Did you know relation between Tree values GST\CGST to the TAXRunTimeLookupCondition table, because based on the tree value the hsncode and related values are changing. For Example
