India GST: HSN code rate upload
I have to upload rate against hsn code for one of our client. I didn’t get any standard entity in dixf. I want to upload it using x++ code but not able to understand table architecture which seems complex. Can anybody help me to come out from this issue. Any help would be appreciated.
dynamicsuser.net/…/how-to-import-data-in-india-tax-setup-gst
Hi Kranthi,
thanks for your reply.
I already checked above three tables. what I understand that we can insert Hsn code, Sac code, Transaction Date From, Transaction Date to and value. this all values are inserting in TaxRuntimeLookupCondition and TaxRuntimeLookupMeasureResultDetail table. But how can we identify that the record which we are inserting that inserting against correct taxtype like CGST, SGST. I am not able to find reference for taxtype in TaxRuntimeLookupCondition table. there are no column which suggest this record inserted agains CGST or SGST.
please suggest.
awaiting for your valuable suggestion.
hi akshay,
have you found the solution, if yes then please mail me on my id foreverfriends75@gmail.com
I want to calculate the gst percentage on customize form.
sorry for late revert. actually i wa
static void CGSTRateUpload(Args _args)
    TaxRuntimeLookupCondition               taxRuntimeLookupCondition,taxRuntimeLookupConditionSort;
    TaxRuntimeLookupMeasureResult           taxRuntimeLookupMeasureResult;
    TaxRuntimeLookupMeasureResultDetail     taxRuntimeLookupMeasureResultDetail;
    int                                     rowinserted, rowfailed;
    ERComponentLookupConditionDimValue      consumState,hsnCode,sacCode,partyGstReg,TaxDirection;
    TaxRuntimeTaxMeasureValue               Value;
    FromDate                                TransactionDateFrom;
    ToDate                                  TransactionDateTo;
    Dialog              dialog;
    DialogField         dialogField;
    SysExcelApplication application;
    SysExcelWorkbooks workbooks;
    SysExcelWorkbook workbook;
    SysExcelWorksheets worksheets;
    SysExcelWorksheet worksheet;
    SysExcelCells cells;
    COMVariantType type;
    int row = 1;
    Name name;
    FileName filename;
    dialog      = new dialog("Dialog");
    dialogField = dialog.addField(extendedTypeStr(FilenameOpen));
    dialog.run();
    if (dialog.closedOk())
        filename = dialogField.value();
        application = SysExcelApplication::construct();
        workbooks = application.workbooks();
        try
            workbooks.open(filename);
        catch (Exception::Error)
            throw error("File cannot be opened.");
        workbook = workbooks.item(1);
        worksheets = workbook.worksheets();
        worksheet = worksheets.itemFromNum(1);
        cells = worksheet.cells();
        try
            do
                row++;
                ttsBegin;
                taxRuntimeLookupCondition.clear();
                consumState = cells.item(row,1).value().bStr();
                hsnCode = cells.item(row,2).value().bStr();
                sacCode = cells.item(row,3).value().bStr();
                TransactionDateFrom = cells.item(row,4).value().date();
                TransactionDateTo = cells.item(row,5).value().date();
                partyGstReg = cells.item(row,6).value().bStr();
               // TaxDirection = cells.item(row,7).value().bStr();
                Value = cells.item(row,7).value().double();
                if(!hsnCode)
                    hsnCode = strltrim(num2str(cells.item(row,2).value().double(),20,0,0,0));
                    if(hsnCode == "0")
                     hsnCode = "";
                if(!sacCode)
                    sacCode = strltrim(num2str(cells.item(row,3).value().double(),20,0,0,0));
                    if(sacCode == "0")
                     sacCode = "";
                if(!partyGstReg)
                    partyGstReg = strltrim(num2str(cells.item(row,6).value().double(),20,0,0,0));
                    if(partyGstReg == "0")
                     partyGstReg = "";
                    select maxof(SortNumber) from taxRuntimeLookupConditionSort where taxRuntimeLookupConditionSort.LookupVersion == 5637145338
                                                               && taxRuntimeLookupConditionSort.Ledger        == 5637154330;
                   /* select firstOnly1 taxRuntimeLookupConditionSort order by taxRuntimeLookupConditionSort.RecId desc
                    where taxRuntimeLookupConditionSort.Ledger        == 5637154330
                    && taxRuntimeLookupConditionSort.LookupVersion == 5637145338;*/
                    ttsBegin;
                    taxRuntimeLookupCondition.initValue();
                    taxRuntimeLookupCondition.DimValue1             = consumState;
                    taxRuntimeLookupCondition.DimValue2             = hsnCode;
                    taxRuntimeLookupCondition.DimValue3             = sacCode;
                    taxRuntimeLookupCondition.DateRangeFrom1        = TransactionDateFrom;
                    taxRuntimeLookupCondition.DateRangeTo1          = TransactionDateTo;
                    taxRuntimeLookupCondition.DimValue4             = partyGstReg;
                   // taxRuntimeLookupCondition.DimValue5             = TaxDirection;
                    taxRuntimeLookupCondition.LookupVersion         = 5637145338;  // CGST RecId
                    taxRuntimeLookupCondition.Ledger                = 5637154330; // Current Company
                    if(taxRuntimeLookupConditionSort.SortNumber == 0)
                        taxRuntimeLookupCondition.SortNumber            =  36;
                    else
                        taxRuntimeLookupCondition.SortNumber            = taxRuntimeLookupConditionSort.SortNumber + 1;
                    //taxRuntimeLookupCondition.validateWrite();
                    taxRuntimeLookupCondition.insert();
                   /* update_recordset taxRuntimeLookupConditionSort
                    setting SortNumber = taxRuntimeLookupConditionSort.SortNumber - 1
                    where taxRuntimeLookupConditionSort.SortNumber > taxRuntimeLookupCondition.SortNumber
                    && taxRuntimeLookupConditionSort.LookupVersion == 5637145338;//taxRuntimeLookupCondition.LookupVersion;*/
                    taxRuntimeLookupMeasureResult.LookupCondition = taxRuntimeLookupCondition.RecId;
                    taxRuntimeLookupMeasureResult.OwnerRecId = 5637145343;
                    taxRuntimeLookupMeasureResult.OwnerTableId = 104845;
                    taxRuntimeLookupMeasureResult.insert();
                    TaxRuntimeLookupMeasureResultDetail.LookupMeasureResult = taxRuntimeLookupMeasureResult.RecId;
                    TaxRuntimeLookupMeasureResultDetail.Measure =  5637145328; // Current Active GST
                    TaxRuntimeLookupMeasureResultDetail.Value = Value;
                    TaxRuntimeLookupMeasureResultDetail.insert();
                    ttsCommit;
                    rowinserted++;
                //warning (strFmt("Row : %1 item : %2 Code: %3 Updated ", row, cells.item(row, 1).value().bStr(),cells.item(row, 2).value().bStr() ));
                type = cells.item(row+1, 1).value().variantType();
                ttsCommit;
            while (type != COMVariantType::VT_EMPTY);
            ttsAbort;
            throw error(strFmt("Exception orrcured in line %1",row));
        application.quit();
        info(strFmt("Total Row Failed: %1", rowfailed));
        info(strFmt("Total Row Inserted: %1", rowinserted));
s logout from site so that i didn’t get notification. might be you already get solution if not check below code.
