For getting consumption of material against a work centre i had done the following things :
added "Prod. Order Routing Line "as first Data Item
added “Prod. Order Component” as second data item and indented it.
Iam getting exact results what i want but i want to add the quantity field of “Prod. Order Component” .
So how to do this plz suggest me from report point of view but no from form ot table point of view that is i dont want to add any field in table and write a code.
For getting total of quantity, you can define for that DataItem, its TotalFields as Quantity (for DataItem, Prod. Order Component >>Shift F4>> TotalFields: Quantity) and then add a footer in the report and display Quantity in this footer.
Are you using “Quantity” field or “Expected Qty. (Base)”??
You mentioned in one of your previous posts, that you want to know the total consumption at the end of the day, if that is the requirement then you need to consider the “Finished Production Orders” also. The entries for “Finished Production Order” will be there in “Item Ledger Entries” table.
