Running NAV2009 SP1, the report 5605 - Fixed Asset - Book Value 01 does not render correctly for some users. When a user runs the report the margins are all messed up and shifted way left the last column that shows the values are half cut off and the last 3 columns do not show. When another user runs the report it renders correctly. These users are both using nav through citrix. I run the report same issue i can not see the last 3 columns, but if i run the report through my local copy on my computer it renders fine. I have copied the users zup file that renders correctly but that still didnt solve the problem. I have made sure to set the same zoom to fit. This is really weird any suggestions ?
