Dear All,
i have 15 fields in a table. the 15th field is total
i need to set the Total as
total = ( ( field1 + field 2 +…field 14) / 8 )
Please can any guide me in this:)
Dear All,
Hi Shona,
You can put your function on OnValidate of each field (1…14). But why would you need this??
-TR-
Are you suggesting that i create an Global value Total and add the fields and paste the same code in all CAL of the fields?
i need to calculate the total for my table thats why i need it.
sorry some default message said my post As not been posted so posted the same again.
You mean Global Variable?? Not necessarily.
I’m afraid so.
I was just wondering why don’t you use a form or report to get the total of your table. If you do this, you will only create a function once and assign it as your SourceExpr(ession)
-TR-
can you explain about this please:) 'm using form.
oh i have created a list form and have 15 fields. since its like i want the total of each row. so cant use the text box right? i have a field called total like this.
But have you tried this??
yes i changed the one i previously created as you said! stil i cant seem to get the result.
Total () :Decimal
l_Total ==> Local Var
l_Total := 1 + 2 + 3 + …+14; //This 1 2 3 referring to your Field Name
EXIT(l_Total)
-TR-
hey tony thank for all your help. have solved my trouble.
Instead of Rec.field i was using xRec.field. that was the problem:)
oh i just used the fields name its like this.
Field15 := ((field 1 + …+field 14 ) / 8)
but thanks:)
