hi dear please give me solution regards this …
i am a new comer in ax…
public void modifiedField(fieldId _fieldId)
//SubjectsTable subjectsTable = subjectsTable.Total;
str a;
switch(_fieldId)
case fieldnum(subjectsTable, English):
case fieldnum(subjectsTable, Hindi):
case fieldnum(subjectsTable, Maths):
case fieldnum(subjectsTable, Civics):
this.Total = this.English+ this.Hindi+ this.Maths+ this.Civics;
this.Total = a;
b = this.Total / 4;
this.
super(_fieldId);
int a,b; // int a sotred value and b is str please solve the below code by summing fields.
switch(_fieldId)
case fieldnum(Student_EduCopy, Subject1):
case fieldnum(Student_EduCopy, Subject2):
case fieldnum(Student_EduCopy, Subject3):
a = this.Subject1 + this.Subject2 + this.Subject3;
this.Total = a;
b = a/3;
this.Percent = b;
break;
default:
super(_fieldId);
Ask your question clearly…
is this ur trying to add the int and str values is it right?
use the global function
int a=10,c;
str b=“5”;
c=a+Global::str2int(b);
info(strfmt(“added value is:%1”,c);
Shaik,
Plz make clear what is the issue you are facing?
Acctually my leader was given a small project
student and subject
i created 2 tables as like ,ok my question is i wana show u when i given marks in contain subjects on that time total field should be hire.
so that i was adding but giving error…
str a;
switch(_fieldId)
a = this.English+ this.Hindi+ this.Maths+ this.Civics;
this.Total = a;
b = this.Total / 4;
this.percentage = b;
default ;
break;
super(_fieldId);
plz ans me dear…
can u pls mention that error?
Shaik,
Do you want to get total of marks in all 4 subjects? Is this what u want? What else you require you write clearly, i ll send you the code.
Trish!
operands types are not comaptable with the operator.
yes u got my question dear…
StudentTable studentTable;
real a,b;
switch(_fieldId)
a = studentTable**.English+** studentTable**.Hindi+** studentTable**.Maths+** studentTable**.Civics;**
studentTable**.Total = a;**
b = studentTable**.Total / 4;**
studentTable**.percentage = b;**
default ;
break;
super(_fieldId);
Work with his code.
Along with this you have to change you switch case also, as per i am concern. Tell me on what condition you have used this switch case?
Trish!
same error dear …
just i wanna add the subject fields and getting total as well as percentage in the form node.
just i wanna complete the modified field that’s it please dear.
hi i wanna give marks in that subjects fields on that time total and percentage will auomatically hire.
plz send me code…
Shaik,
Forget every thing. goto table > override modifiedField() > paste this code
public void modifiedField(FieldId _fieldId)
this.Total = this.English + this.Maths;
this.Percentage = this.total/2;
super(_fieldId);
you are done. as soon as u ll enter the values in subjects you will get the total and percentage. No need of switch-case my friend.
Happy!
Trish!
ok i wll try dear but must using modified field()
hello shaik
while inserting onwards you wanna to calculate means just write this same coding in insert method of table
table->methods->overide->insert
then you can get that value
public void insert()
super();
shaik your error
i think you created one of ur field is string
check whether your created all the fields as interger
you cannot calcualte like this
string=string+integer;//so check your table
yeh i got same thought dear waw i got it just now thanks for co - opration dear but quickly response dear next time
thanks love u
