Dear Sir… My consultant found error while running adjust cost FIFO method by So… before running adjust cost I know it issue by average eventhough I set method by item is FIFO thus for correct costing I must be calculate by runing adjust cost but result is wrong by Item is calculate Item Dear Sir… My consultant found error while running adjust cost FIFO method by So… before running adjust cost I know it issue by average eventhough I set method by item is FIFO thus for correct costing I must be calculate by runing adjust cost but result is wrong by Item is calculate Item by lot tracking Ohh god… Why 's costing using lot for calculate too in example : Item A have lot Before calculate PO(GRV lot 01) 01/01/05 Item A 10 @10 PO(GRV lot 02) 02/01/05 Item A 10 @20 PO(GRV lot 03) 03/01/05 Item A 10 @30 SO(lot 01) 04/01/05 Item A -10 @10 SO(lot 03) 05/01/04 Item A -10 @10 After calculate PO(GRV lot 01) 01/01/05 Item A 10 @10 PO(GRV lot 02) 02/01/05 Item A 10 @20 PO(GRV lot 03) 03/01/05 Item A 10 @30 SO(lot 01) 04/01/05 Item A -10 @10 SO(lot 03) 05/01/04 Item A -10 @10 ??? 05/01/04 Item A 0 @20 ??? Can you explain me Why lot tracking is involved in method of adjust cost ?
Please post to correct forum. This is about errors in the website! You’s is about error in Navision. Topic moved.
