Is it possible (invent table) to make the options available in one field dependent on another ?
e.g.
If Cost group = “A” then Stock model group can be A, B or C
If Cost group = “B” then Stock model group can be A, D or E
etc
e.g.
etc
Yes. You can override the lookup,validate methods of the fields depending on the requirement.
But before that you should have mapping of the explained example.
Hi. I have the same problem. how can i do this?
Regards
