Hi, all I started learning EP. I am using Axapta 3.0 SP3, I imported the demodata that went with the SP3 release. But the EP data there is limited - meaning there are no web parts or web panels whatsoever. I would like to ask if anyone knows of a link, where I can download the DemoData for Axapta with panels and web parts. Thanks
Hi Kashperuk,
It has been a while since I worked in EP. If my memory serves me correct, there is no separate demo data available for EP.
When you import the demo data it should import four odd web parts and around ten web panels I think.
Well, in my case it’s 2 web panels (lines like 1 - 1 and 2 - 2) and 1 web part Yours is better, i guess I guess I will just have to create them myself. the only problem is identifying the weblet that is going to be used for each one. Thanks for the reply
