New at Nav. I got a small issue. I am sending emails using the code 400 SMTP in Nav. How do I check if the message has reached the destination. If sent to a non-existent address, I get the error message in Outlook but in Nav there’s no error code raised.
The SMTP component would only fail it was an invalid email address. A valid email address does not necessarily exist on the receiving server, so the server sends a non delivery report back to the sender email notifying that the recipient doesnt exist.
That is why you only get this notification in Outlook or what email program you are using.
With the existing SMTP functionality i dont think there is any workaround. The email is sent from your SMTP server, so everything looks good in the SMTP component you are using.
In order to make sure the email was received/read, you would probably need to put some kind of tracking image in there, that you have on a webserver where you can see if it was accessed, and then do your updates to mark it as read in NAV.
As long as you are not sending unsolicited emails, there should not be an issue tracking if the receiver “read” the email. You could take a look at http://msgtag.com/home
Anyways, this question is beyond the scope of this forum.
