When I try to add tables Main Account and DimensionAttributeValueTotallingCriteria into Excel via the Dynamics ax Add in I get the following error:
An Error Occurred. The data in the workbook and the behaviour of any add-ins may not be correct. Consider contacting your system administrator about this problem.
Object reference not set to an instance of an object.
The issue seems to be linked to DimensionAttributeValueTotallingCriteria table. All other tables seem to add without any problems.
I know this table is populated by financial Dimensions but not sure as to why I can’t load the table into Excel.
Anyone have any suggestions? Would be much apreciated.
Steve
