Product templates in ax 2012
I have one template for Release Product master taken from one system, but when open this in another client system it throw some errors
Microsoft Dynamics AX Office Addin
An error occurred. The data in the workbook and the behavior of any add-ins may not be correct. Consider contacting your system administrator about this problem.
Object reference not set to an instance of an object.
OK
Can any one help on this?
I am also facing the same issue. any one can help me it’s urgent .
Phani
I’ve had similar issues because the connection information is wrong. From excel, Dynamics AX tab, options. You may see the error again - just hit ok and make sure all the information on the form is ok.
hiii guys
I was also getting the same error , den i cheked in" com addins " in manage which u can get from options .
