Hi
i have some requirement where i need to create the temporary table dynamically.Please anybody can help me how to create the table dynamically.
Thanks & regards
Bijesh kumar singh
Hi
Thanks & regards
Bijesh kumar singh
You can use the below code in order to create the ‘table’ in ax:
static void Tbl(Args _args)
#aot
#properties
SysDictTable sysdictTable;
treenode trv;
AOTTableFieldList fieldnode;
str prop;
int pos;
trv = treenode::findNode(#TablesPath);
//trv.AOTDrop(‘AAA’,1);
trv.AOTadd(‘AAA’);
trv = trv.AOTfindChild(‘AAA’);
trv.AOTcompile(1);
trv.AOTsave();
fieldnode = trv.AOTfirstChild();
fieldnode.addString(‘AccountNum’);
fieldnode = fieldnode.AOTfindChild(‘AccountNum’);
prop = fieldnode.AOTgetProperties();
pos = findPropertyPos(prop,#PropertyExtendeddatatype); //find right place to put extended data type
pos = strFind(prop,‘ARRAY’,pos,strLen(prop));
pos = strFind(prop,’#’,pos,strLen(prop));
prop =strins(prop,extendedTypeId2name(ExtendedtypeNum(CustAccount)),pos + 1);
// insert field of extended data type ‘CustAccount’
fieldnode.AOTsetProperties(prop);
trv.AOTcompile(1);
trv.AOTsave();
trv.AOTRestore(); //to load assigned extended data type properties
sysdictTable = sysdictTable::newTreeNode(trv);
appl.dbSynchronize(sysdictTable.id());
Hi Vishal
Thank you very much it working fine.
Thanks & Regards
Bijesh kumar singh
