I have a lookup for sales order no field and it displays all fields in salestable table in this sales table there is a field displaying status of the sales whether it is open order or invoiced,etc. Now what i need to know is the lookup need to show only the details related to open order (i.e) in the status field I need only the open order sales must be shown I don’t want other invoiced or posted records to be displayed. I use AX 2009 version.
Thanks & Regards,
Raaj
You can filter it in the select/while condition.
SalesTable.SalesStatus::OpenOrder;
Hi Vijay,
Can you please give me a detailed explanation with sample coding.
This method will help you: http://daxtechies.blogspot.in/2013/03/lookup-or-drop-down-for-field-in.html
Table name will be ‘SalesTable’ and under range you can pass ‘SalesStatus’ as Open order
You can also do it through relations. Give relation with sales table on your table where you want the lookup
Normal = SalesId to SalesId and
Related Fixed Field 1 = SalesTable.SalesStatus
Hi Naveen,
Please try to override lookup method of the string edit control SalesId. In that you have to write code for building x++ query. in that you can add datasources, ranges and can provide the range value as well. Then it will filter the lookup based on the range value like all the open sales orders.
Vijay Solanki.
Your lookup method will have this code. The SaledIdEdit is the string control in my case, in which I am performing the lookup and override the lookup method of this control. Try this snippet, I hope you will find your answer. Don’t forget to mark this as solution.
public void lookup()
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tablenum(SalesTable),SalesIdEdit);
Query query;
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
// Parameter “true” indicates what field
// is returned to the form
sysTableLookup.addLookupfield(
fieldnum(SalesTable,
SalesId),
true);
SalesName));
SalesStatus));
query = new Query();
// Add datasource to the query
queryBuildDataSource = query.addDataSource(
tablenum(SalesTable));
// Add sorting index to query
queryBuildDataSource.addSortIndex(
indexnum(SalesTable,
SalesIdx));
//Add range to the query
queryBuildRange = queryBuildDataSource.addRange(fieldNum(SalesTable,SalesStatus));
queryBuildRange.value(enum2str(SalesStatus::BackOrder));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
Thank you Vijay, Vishal and Anand I don’t know who’s suggestion helped me but I got the solution.
Thanks & Regards,
Raaj
