Hi Pioneers,
I have my requirement as below:
In “SalesTable”, I have to put a lookup for “SalesStatus”, as when I select “Open” in lookup, the records in “SalesTable” form, should get filtered with those “SalesOrders”, whose “SalesStatus” is “Open”, if when I select “Invoiced” in lookup, the records in “SalesTable” form, should get filtered with those “SalesOrders”, whose “SalesStatus” is “Invoiced”. I am new to Ax , please guide me.
You can override the lookup() method of the data source field (or the form control, if it’s not bound to any data source field) and add a range there. See How to: Add a Lookup Form to a Control.
Hi Martin,
Thanks a ton !!!
How many lookups should I write ? For example, should I write a lookup for filteration on the basis of “Open Orders”, “Invoiced Orders” etc. ??? Or may I write “selectionChange()” method ???
There is just one lookup method for the field. What you need to do is setting the range value from your parameter. For example:
statusQueryBuildRange.value(queryValue(statusParameter.selection()));
