Dear Friends
What is DictTable? Why we sue this and what is the purpose.
I will waiting for you reply
Regards
Venkey
Dear Friends
Regards
Venkey
DictTable is a class that provides information about tables (and maps and views). It will tell you, for example, how many fields a table has. Look at its methods in documentation on MSDN.
It is one of the Refection API available in AX, helps to get the metadata of the tables. Example: the field count using
\System Documentation\Classes\DictTable\fieldCnt
index count, \System Documentation\Classes\DictTable\indexCnt
Hi Kranthi,Adam
is there a way to read the code in the method of dictable (dataPrCompany)
DictTable.dataPrCompany().
i assume that this is kernel application we can’t read or modify… but i passionate to understood the way they implemented here…
No, it’s not possible. It’s a kernel class, i.e. it’s compiled C++ code or something.
Nevertheless I believe that it simply looks at SaveDataPerCompany property on table.
thanks Adam
Please mark a reply (replies) that helped you as the verified solution.
By the way, I’m not Adam.
sorry by the mistake…
Thanks Martin…
By the way I’m not able to mark it as a verified solution as I.m not the author [:D]
Ah, I didn’t notice. Please create a new thread next time.
