Delivery note against multiple invoices
Dear All,
Is it possible to link the delivery notes against multiple invoices in Ax 2009 0r Ax 2012. can any one help in this regards.
Nanjappa
Yes but it is the reverse, you process an invoice against the receipts or part receipts to get multiple receipts linked to invoices. Not clear if this is AR or AP, but either you can do it.
Thanks Adam,
This is for Accounts Payable, can you explain how to do this process.
Nanjappa
It is just standard invoice processing, you bring in the delivery note and define the quantity through the process leaving the balance remaining, but there are a few configuration elements here so it will depend upon your matching rules etc. What have you tried and where does it not work for you?
