In Ax2009 existing date format is mm/dd/yyyy . We want this to be dd/mm/yyyy.
Any suggestions to change it in all our applications.
Regards
Regards
It uses user’s date format from Windows (Control Panel > Region and Language or something like that).
Try changing your system regional settings.
You can also change it By using the data method and declare the field as string and use the
function str2date(Passing the parameter as per enum type selection).
Thanks for the suggestion.
you can use the following code for changing the format of date in ax
dt=today();
datestr(dt,123,2,4,2,4,2);
here
dt is todaysdate,
“123” means,1 for day,2 for month,3 for year,u can also reorder these
“2” for printing the day or month or year as per u r chosen format
“4” for seperator like /,-, etc whatever u want
“2” for month
“4” for seperator
"2 "for year
fas per u r requirement u can use above code
check this
Regards
Dhinu.v
Hello,
Check the extended datatype that extends your date, probably transdate datatype and change the date format properties to force to the dd/mm/yyyy format you want.
Thomas
Hi Dhinu,
Thanx for the nice explanation
