I’m trying to use ADCS with my own customised tables for a client solution. Any documentation on the subject or has anybody tried before - basically I want to know whether it is so complicated as it looks.
No it is not as complicated as it looks. Once you go thru the code for one functionality you can easily write custom applications
only thing is that you need Warehouse Management as well Warehouse management Systems, including ADCS that means over 13.000 euro’s or 12.000 dollars…
Thanks, I am aware of the required granules. In the last couple of days I have been able to start building and accessing my own miniforms, but its a slow process - do you know of any documentation on the subject ex Navision?
