I want a X++ job to update the customer phone number i will pass the customer code and new phone number in the job and it should update the customer phone for the specified user.
Please i been searching all over and could not found the solution thanks.
instead of job you can export existing data in excel through AX. Prepare data only mandatory columns with phone no and import ie update that respective data only.
But i have a requirement to update using the 3rd party application i am using .Net business connector for this thats why i need the code using the x++ i need the code to make this update.
