Customer Aging Buckets form is not displaying the data....?
Hi Guys,
When I am trying to view aging buckets for a customer the information is blank (AR/Customer/Balance/Aging Buckets).
Even there is setup for Aging Buckets functionality…
Thanks In Advance…
There is a periodic job that you have to run before you can see the aging buckets in the collections form.
Run this process and open the collections form.
Best regards,
Ludwig
Can you tell me from where I can run that Job and the Job name…
Thanks in Advance…
Not aware of any periodic jobs. As long as set-up such as aging period definitions are set correctly and there are no customizations, you should be able to view the balances.
Steps for this set up may be found here - http://mustafachohan.blogspot.com/2012/01/aging-buckets-in-microsoft-dynamics_21.html
Hi Harish Mohanbabu,
Thanks for your reply… The setup for Aging buckets is already existing and it was working fine… but suddenly it stopped working and not able to see data in
Aging buckets for a customer (AR/Customer/Balance/Aging Buckets) form
And This issue is in AX 4.0…
Thanks in Advance…
