Dear Reader,
Thanks in advance, i am trying my best to explain the scenario
I need to develop a lookup on a form, the requirement is as follows
there’s a field called TransactionDate in the Header Table,
there’s another field called Description in the Lines Table,
I want to populate a lookup on the Description field which contains timeslot ranges (for e.g from 00:00:00 hrs to 06:00:00 hrs) this timeslot range is based on the ‘effective from date’ and ‘effective to date’ (for e.g 01-Apr-2012 to 31-03-2012)
Now if the Header Table’s TransactionDate falls in between the ‘effective from date’ and ‘effective to date’ period then only those timeslot ranges should be displayed in the lookup.
Note: the lookup which will be populated comes from a different master table which doesn’t have any field common with the header and lines table.
Please suggest a solution for the above.
Prashant
