Hello,
I am new in Dynamics AX 2012, I have created my form with fields (ID, dated, DATEF, code), and a new table I want the combobox ID in my form displays all data of my table using a lookup , I saw a lot of tutorial but it did’nt work
Regards.
Hello,
Regards.
If you are using the same table in form, then why do you need a lookup? The form is UI to enter the data into the table
If you are using the Id/code from this table in another table, use a relation to get a lookup…
“It didn’t work” is never a sufficient description of any problem.
I am trying to learn ms dynamics ax2012
by making some practical work. I’m trying to make a lookup form
to show some data of my new table in drob down. here i have did that;
reference
with the field RefID
and others fields(date1 ,date2…).RefID
field to the Index.a) AllowDuplicates to “NO”.
b) Alternate key to “YES”.
PrimaryIndex
property of the table to newly created index after creating therefEdt
and i set reference table property to my tableLookupform
i add in datasource my new table ‘reference’combobox control
i add datasource property 9; i add ReferenceGroup control
with datasource property , but i can’t set ExtendedDataType
= {my EDT name} is not displayedany ideas to improve my Testof lookup
best regards
Aha, so you’re the same ahmed as in How to create a lookup form, correct? Why did you post exactly the same thing again and under a different account? Please try not to make more chaos necessary.
Everybody please continue the discussion in How to create a lookup form.
No, I’m not the same person why you say that, it seem to me that we have the same problems
And by coincidence, you formulate your problems in exactly the same words, including sentences like “any ideas to improve my Testof lookup”. Very convincing. [:)]
