hi ,
i am trying to import data from CSV file to AX using Batch job the code is like
Job
static void Job_ScheduleBatch2(Args _args)
ReadCommaFile1 ReadCommaFile1;
BatchHeader batHeader;
BatchInfo batInfo;
RunBaseBatch rbbTask;
str sParmCaption = “RAMU”;
rbbTask = new ReadCommaFile1();
rbbTask.getRunBase();
batInfo = rbbTask .batchInfo();
batInfo .parmCaption(sParmCaption);
batInfo .parmGroupId(""); // The “Empty batch group”.
batHeader = BatchHeader ::construct();
batHeader .addTask(rbbTask);
batHeader.save();
info(strFmt("’%1’ batch has been scheduled.", sParmCaption));
class
public class ReadCommaFile1 extends RunBaseBatch
Table1 table1;
Name sno,sname;
#define.CurrentVersion(1)
#localmacro.CurrentList
sno,
sname
#endmacro
public void run()
CommaTextIo file;
container line;
#define.filename(@‘C:\Users\ramu\Desktop\ramu.csv’)
#File
file = new CommaTextIo(#filename, #io_read);
if (!file || file.status() != IO_Status::Ok)
throw error(“File cannot be opened.”);
line = file.read();
while (file.status() == IO_Status::Ok)
table1.sno = conPeek(line,1);
table1.sname = conPeek(line,2);
table1.insert();
info(con2Str(line, ’ - '));
line = file.read();
public container pack()
return [#CurrentVersion,#CurrentList];
public boolean unpack(container _packedClass)
Version version = RunBase::getVersion(_packedClass);
switch (version)
case #CurrentVersion:
[version,#CurrentList] = _packedClass;
break;
default:
return false;
return true;
protected boolean canGoBatchJournal()
/* boolean ret;
ret = super();*/
return true;
public boolean runsImpersonated()
/* boolean ret;
ret = super();*/
return false;
I need to insert data daily, suppose every day 9 am this job need to run. but i shows error as follows
Request for the permission of type ‘FileIOPermission’ failed.
(S)\Classes\FileIOPermission\demand
(S)\Classes\CommaTextIo\new
(S)\Classes\ReadCommaFile1\run - line 13
plz provide solution for this in advance thanks
ramu@sunbridgeindia.com
