Hi guys, I’m looking for some advice/help on the below problem.
I’ve created a new Custom Field (via Purchase Order form) and the field it is now part of the PURCHTABLE (per SQL Server screen dump below).
However, after adding the new field, when I go to System administration >>Setup>>Custom fields and select the PurchTable, my NEW field does not display?
I’m trying to add the new custom field to a data entity via this option.
Is there something I’m missing?
Can you advise please? (ps: I’m testing on USMF company on my test instance)
Hi Jake. Thanks for taking the time to reply. On watching your video, this is exactly the routine I used. My custom field is a text field. But the Data Entity part of the functionality just does not work in my instance. As I said, I’ve added the custom field and it belongs to the PURCHTABLE. But when I highlight PURCHTABLE in the dropdown list, and click “Select” nothing happens! Both the General and Entity tabs show nothing. It just doesn’t work! I don’t know what to do next…
