internal final class RunnableClass1
/// CustomFieldloc we created customfield on HCMsharedparametertable.
public static void main(Args _args)
HcmSharedParameters HcmSharedParametersLoc, HcmSharedParametersLoc1 ;
UserGroupInfo UserGroupInfoloc;
CustomField CustomFieldloc;
UserGroupList UserGroupListloc;
select firstonly * from UserGroupInfoloc where UserGroupInfoloc.RecId == HcmSharedParameters::find().CustomFieldloc;
while select UserGroupListloc where UserGroupListloc.groupId==UserGroupInfoloc.id
DirPartyName PersonName = DirPersonUser::userId2Name(UserGroupListloc.userId);
It would help if you explained your problem - it’s not clear which part you’re struggling with.
It may be beneficial for you if you rewrite code to a single query, because that’s what you need in AOT. Then you’ll implement the same structure in AOT.
For example:
DirPerson person;
DirPersonUser personUser;
UserGroupInfo userGroupInfo;
HcmSharedParameters hmcSharedParams;
UserGroupList userGroupList;
select person
join personUser
where personUser.PersonParty == person.RecId
join userGroupList
where userGroupList.UserId == personUser.User
join userGroupInfo
where userGroupInfo.Id == userGroupList.GroupId
exists join hmcSharedParams
where hmcSharedParams.UserGroupInfo == userGroupInfo.RecId;
By the way, Scarlett_Jonathon is an AI bot (source).
