What are the steps to correct or re-price a posted consignment pricing error?
thanks in advance
Evan
thanks in advance
Evan
Use Item Revaluation
Where is this located - still can’t find it.
Find Revaluation Journal
It is location under Warehouse → Inventory
Would the steps include: selecting the row with the specific item# and External Doc# then click on the ‘Item’ button and then clicking on the ‘Value Entries’ menu option?
Once you have entered the Item no ,External document no and then select field Applies to Entry field. It will open the Item ledger entry select the entry which you want to revalue .After selecting It will update the information in journal such as Unit cost(Calculated) ,Inventory value(calculated) and others info
.After this kindly modify/update the unit cost (revalued) which you want to revalue with.
Post the journal
This will revalue the entry you have selected.
