hi
i have two tables 1. postable 2.sostable
postable fields are Custacct, Custname,Addresss, COntactNo
Sostable fields are Accid ,Name
i want to move the all Cust acct field values to Accid ,CustName values to Name
how to do it …
hi
how to do it …
Do you want to copy all records from one table to the other? In that case, I would use insert_recordset. See the following example (not tested):
insert_recordset sosTable (AccId, Name)
select CustAccount, CustName from posTable;
its not working …
