Copy values from -> to table
Hello everyone,
I want to copy values from 2 fields from one (table2) to another table (table1), but it’s not working.
This is my job.
void copyFromToTable()
table1 table1;
table 2 table 2;
ttsbegin;
insert_recordset table1(field1, field2)
select field1, field2
from table2
ttscommit;
Can anyone tell me what I am doing wrong?
Thanks!
What exactly happens? Do you get any error?
No, nothing is happening.
I am using AX 3.0
If you execute the select alone, do you get any data?
If you override insert() on Table1 and put a breakpoint there, does it get called?
Hi Martin,
Thanks for your help. I fixed it like this…
static void copyFromToTable(Args _args)
table1 table1;
table2 table2;
while select table2
table1.field1 = table2.field1 ;
table1.field2 = table2.field2;
table1.insert();
info(strfmt(“Mission Accomplished”));
