Hello Everyone,
How could i clear the fields of a page after having some actions done??
Is it Possible to open the Customer Card in page mode-New?
Working on Nav13 R2
Thanks in advance
Hello Everyone,
Working on Nav13 R2
Thanks in advance
You need to open the customer page from any action?
if yes, when you add the action in page then there is a property called RunPageMode for that action
set it to Create Mode and try
Thanks Mohana
But i need to open the page from runmodal(21) using code??
N can u also suggest me how to clear all the fields in a page after an action?
click the new button.
by code, try following:
write in action trigger.
create a local var.rec2 of same. type as rec.
rec2.init;
rec = rec2;
currpage.update;
